Want to replace the jack input
My jack input has got really loose and my jack cable keeps falling out.
How do I replace the jack input with a new one?
Esta é uma boa pergunta?
Unfortunately, the headphone jack on this machine is directly soldered to the logic board. If you can source a part and you're really good at soldering, the part can technically be replaced. Otherwise, it may be possible to bend out the contacts from the outside of the jack. If you check out the picture on this step (step 32), the headphone jack is closest to the front of the picture. I cannot verify that this can be done (because I've never done it), but it may be possible to pry the steel casing off the outside of the headphone jack casing and that may allow you to use a metal awl to push the contacts down into the inner barrel of the headphone jack, making the connection more secure.
Esta resposta foi útil?
maybe you could describe what i have to do so the connection could be more secure?
No Magnus, forget what Andrew suggested. you will end up ruining that connector for good. instead, try looking for replacement USB headphone jack. they come cheap and often have better sound than built in...
I have done something similar, with one white macbook, it had a bit of jack stuck in it. i have ended up completely taking apart the connector, drilling through and pushing it out using needle file, unfortunately, i must have damaged something in it. it did not give me a single sound.
http://www.youtube.com/watch?v=_W0rhmzMg...
see how to fix your jack output
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 17,977
