Ir para o conteúdo principal
O iPhone 5C da Apple foi lançado em 10 de Setembro de 2013. O reparo deste smartphone é similar aos modelos anteriores. Você precisará de chaves de Fenda/Philips/Torx 0.8 e espátulas de plástico. Disponível nas versões GSM ou CDMA / 8, 16, 32 GB / Branco, Rosa, Amarelo, Azul e Verde.
1233 Perguntas Visualizar todos
Why won't anything show up on my screen
About a week and a half ago my friend hit my phone out of my hand and it dropped on the ground. When I picked it up it hadn't cracked or anything and it looked fine but when I pushed the home button green lines appeared on it and it just went black. It wasn't responding to anything until I tried charging it then it made all of the noises that a phone should make, but the screen won't turn on. Please help.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
I would suggest inspecting it and maybe replacing the screen on it. This will most likely fix your problem but if it doesn't then it may be that the battery got disconnected or damaged somehow. However, this is unlikely,especially since you say it had lines on it before it died.
Before you go and buy a new screen, you should open it carefully and make sure the screen is connected properly. This is the most probable cause since there appears to be no physical damage to the screen.
Esta resposta foi útil?
Pontuação 0
2 comentários:
Thank you so much
por
OP: If you are not confident in replacing the screen yourself then I recommend taking it to a mobile phone repair shop.
por
Adicionar a sua resposta
Camryn hartwig será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 52
