Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Model A1237 or A1304 / 1.6, 1.8, 1.86, or 2.13 GHz Core 2 Duo processor
380 Perguntas Visualizar todos
How do I replace this thingie?
I have a MacBook Air with this thingie broken. I don't know what it is but it looks like a piece of plastic. It's at the bottom below the fan and heatsink. What is it and how do I replace it?
Respondido! View the answer Também tenho esse problema
Esta pergunta é pertinente?
Pontuação 3
Adicionar um comentário
Kit de pontas universal para chave
112 bits for every fix.
Upgrade Your Toolbox
2 respostas
Solução escolhida
@gigabit87898 what model MBA? I wonder if you are looking at the hinge (clutch) cover. See if this part looks right. If that is the right part, then use this video to help you with the work. Make sure that you make a guide for the rest of us when you replace it.
Esta resposta foi útil?
Pontuação 5
Comentários:
It's a a1304 emc 2334
por
That looks like the right one, but how do I replace it?
por
@gigabit87898 check the edited answer for the link.
por
@oldturkey03 it looks like you just follow the display replacement and then slide the cover off, the wifi antennas are inside of it so you just slide those into the new one.
por
Pergunta Mais Útil
With the screen facing up and the clutch cover closest to you, slide the clutch cover to the right and gently lift upwards.
Pontuação 6
Comentários:
Can you do this without taking it apart?
por
Adicionar a sua resposta
Gigabit87898 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 189
