Ir para o conteúdo principal
The original Blackberry Bold smartphone, featuring various improvements from older Blackberry models.
11 Perguntas Visualizar todos
My blackberry is overheating all the time
This may sound crazy (or not) but this things overheating
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Sounds like the battery went rogue.
How long have you owned the BB for?
This problem usually happens from your BB being charged in a staggering time line. Plug in for 20 minutes, use for 35, plug in for 5 minutes, use for 10 min.
Doing that and ripping the charge cord out fast (everyone has done it at least once) causes sub surges. That energy is sometimes stored waiting for a another kick to ignite (plugging it back in) so to speak.
Take the BB battery out and plug in your device. Some BBs will operate without battery. Cab drivers used to do this all the time. If it heats up while battery is out, then your device chip and board is causing the over heating. Dropped, moisture, sitting on it time and time again, pocket lint, dust ...all play a role in a device's lifeline.
Shaun
a.k.a. @SinisterCaine
Esta resposta foi útil?
Pontuação 0
Pergunta mais útil
Try it with another battery, this kind of battery they overheat once they are too old or bad.
Pontuação 1
Adicionar a sua resposta
john será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 3,559
