Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Model A1502 / 2.4, 2.6, or 2.8 GHz dual-core Intel processor / Released October 2013
487 Perguntas Visualizar todos
Part of the components covered by a sticker
Inside the 13" MacBook Pro with Retina display Late 2013 there is a part close to the battery with some chips that are covered with a sticker and a warning message. I guess those are related to the battery but could not find anything specific.
After a liquid spill I have cleaned the logic board but the battery is not working and I suspect it could be because it is very sticky on that part (it was Coca Cola, terrible)
Is it safe to clean that part with alcohol as I did with the rest of the components or better not to touch it in any way?
Esta pergunta é pertinente?
Pontuação 0
Comentários:
@claudiosposito " I just checked the battery logic board and one chip looks damaged" and "some chips that are covered with a sticker and a warning message" hard to identify. Post some good pictures of what you see with your question. For that use this guide Adding images to an existing question It will allow us to see what you see.
por
Adicionar um comentário
Kits para o Nintendo Switch
Um reparo rápido para reiniciar o jogo
Confira kits para o Nintendo Switch
1 Resposta
Pergunta Mais Útil
Isopropyl alcohol is safe to use on most PCBs. Don't get it on any mechanical parts though, like optical or hard drives, or fans. Use 70-99% isopropyl alcohol and use a swab to dab it on, then if debris needs to be cleaned off, use a soft cloth. Once the debris is clear, dab on a little bit of alcohol over the surfaces in question, then let it evaporate completely.
Don't get anhydrous alcohol, as pure chemicals can be dangerous and finicky to work with.
Esta resposta foi útil?
Pontuação 1
Comentários:
Thank you for the tips. I just checked the battery logic board and one chip looks damaged, I'll bring it to the Apple Store to replace the battery.
por
Adicionar a sua resposta
Claudio Sposito será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 46
