Ir para o conteúdo principal
Model A1288 / 8, 16, or 32 GB capacity
20 Perguntas Visualizar todos
My iPod won't charge
We have two IPOD NANO's. Both have low battery. I plug in the USB cable to my computer and the other end to the NANO as I always do. The computer brings up ITUNES and it does it's syncing. ..and it says it's OK to disconnect. Then the IPOD gives a message "low battery plug into a power source". Both IPODS say the same thing. If I wait a little bit (ie: 3 minutes) it starts doing the SYNC again repeatedly. I have tried this MANY times all with the same result. The HP computer is plugged in to a wall outlet. I am using the IPOD NANO's USB power cord that came with the device when I bought it. I was able to charge one of the IPOD's last week without any problem. It seems very strange that both of our IPOD NANO's would do the same thing at the same time. Could something be wrong with the USB power cord?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
If both devices are showing the same issue it does sound like the charging cable. Try a different charging cable and that should resolve the issue.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Bruce Thorson será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 5
Duração total: 177
