How can I permanently disable wifi from the 2ds
on the 3ds there is an antenna . the 2ds doesn't have it
Esta é uma boa pergunta?
you dont need to cut any cables, you can setup a PIN code to access the options and just delete all the internet connections and set the pin code up so that nobody can access the settings to setup a connection, pretty much the same effect as removing the WIFI antenna..
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 1,236
Other answers say parental controls. That solution does not work for me. The child still can call nintendo to disable them..
por Samuel Hilton
