battery changed, phone switches off randomly
i've changed my battery, and now it sometimes switches on and stays on, and sometimes randomly powers down, or, sometimes when i switch it on it keeps cycling to the apple screen over and over. the new battery was 57% and then charged up to 100% really fast.
i'm also almost 100% sure about the screws, i stuck them to tape in the right configuration and didn't tighten them too much.
Respondido! View the answer Também tenho esse problema
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
Visite Nossa Loja
3 Soluções
Solução escolhida
Hi,
I would suggest trying another battery replacement, depending where you got it from, it could be a cheap, or faulty battery, try get a replacement. :-)
Esta resposta foi útil?
Pontuação 3
Resposta Mais Útil
Probably a faulty replacement battery
Pontuação 3
Thelia from what you have said I think you have dislodged the gas gauge filter at the back of the battery connector. If you have tried the original battery and the symptoms are the same then a local repairer will be able to fix this quite easy. It is basically a false reading between the board and battery. I am sure you will find gas gauge posts on here for you to confirm this
Pontuação 1
Adicionar a sua resposta
thelia será eternamente grato(a).
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 45
