MacBook Pro Won't turn on after dual disk install
Hello everybody!
I replaced the optic drive on my MacBook Pro 13" Unibody Mid 2009 by an SSD drive.
This is not the first time and I do this kind of hack, but this time, the mac won't turn ON anymore.
I tried all the possible combinations, unplugged the battery, put back the original optical drive... No changes :(
Any clue please?
Thank you for your time!
NM
Esta é uma boa pergunta?
2 comentários
Can you give us a bit more here...
When you hit the power button do you hear the fans as well as the startup Bong? What does the MagSafe adapter LED show you and what does the battery test LED's show?
What happens when you disconnect the battery, RAM, both drives and then power up just on the MagSafe adapter any difference?
por Dan
Hi
Thanks Dan for your answer!
Nothing happens when I hit the power button, no sound, no fan spinning.
When I plug the MagSafe, the led turns to a light green (very weak glow) even when the battery is disconnected.
I tried the same steps with 3 different working MagSafe adapters, with no success :(
por Nas
