Ir para o conteúdo principal
Why won't my brake lights work
I have all lights working Four way flashers, tail lights, turn signals but no brake lights. I have replaced the fuse, the brake light switch, and the bulbs, still nothing what could be the problem?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
3 respostas
Solução escolhida
Do a continuity test on the wire from the brake light switch on the brake pedal to the brake light socket in the rear of the car . There's probably a short in the wire . Hope this helps
Esta resposta foi útil?
Pontuação 2
I figured it out. It was the trailer light wiring harness. The previous owner tried rigging up a homemade wiring harness. Smh, but I just unhooked that one and did it the right way. Now all of the lightsame work. Thanks for the help
Pontuação 1
stoplights go thru the turn signal switch..even tho turn signals work contacts for brake lights may be corrodded
Pontuação 0
Adicionar a sua resposta
Mark Anthony Branch será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 17
Últimos 30 dias: 74
Duração total: 12,356
