Ir para o conteúdo principal
The Motorola Razr V3c is a CDMA2000 version of the Razr.
8 Perguntas Visualizar todos
#7 on key pad is very intermittent (3%)
#7 on keypad hardly ever connects. Verizon sprayed a cleaning product on the external keys. The key "clicks" but rarely makes contact. I like the phone. Repair shops quote $40 to replace the entire keypad.
Thanks for any input.
Joe
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Pergunta mais útil
maybe try taking the plastic frontage off the keyboard and layering a tiny bit of tinfoil underneath it, so the contact has something to touch?
I've done this with other types of buttons before, I believe it might work for you. it's worth a shot, anyway.
hope that helps!
Esta resposta foi útil?
Pontuação 1
2 comentários:
Thank you!. Now I try then I tell you
por
I would use the guide to remove the keypad and would clean the contacts under the adhesive that holds the half button - i never yould use something that could shorten anything inside a phone
por
Adicionar a sua resposta
jbass43314 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 1,476
