volume varies up and down
volume goes very high and low.
Esta é uma boa pergunta?
Hi
Have you checked in the Audio section of the TV Menu to see if the volume leveling setting is turned OFF?
Do not know if this setting is available to you as you didn't specify the model number of your TV.
Here is a link that explains what to do. (if you have it that is)
Esta resposta foi útil?
Wow thank you it worked on my Vizio!!!
I did a factory reset by holding the Bluetooth and volume down button down at the same time for 5 seconds and it solved the problem. YAY. I was living with this for far too long. lol
Thank you so so so so much! I had to watch TV with my phone in my hand because I had to ALWAYS turn volume up and down. This issue was so freaking unbearable!!!!! Thank you!
Thanks for the tip. I was ready to buy a new Vizio sound bar for $228. The volume would just suddenly skip to its loudest mode.
Paul McCarthy
Wow thank you so much. Thought my TV was breakin down.
I had the same problem. The problem in my case was my Firestick. The firestick remote was malfunctioning and constantly turning the volume up. Took the batteries out of the remote and voila!
This worked for me, thanks!
Mute goes on/off when rewinding or fast forward - volume always changes when I use dvr function buttons. I can have volume at 40 and if I do reqind or fastforward the volume will soon be up to 70 or down to 20's. Not a great design.
I had to turn off surround sound on YouTube TV and turn off leveling on my Roku. That seems to have fixed the problem so far. Fingers crossed.
Últimas 24 horas: 23
Últimos 7 dias: 242
Últimos 30 dias: 1,027
Duração total: 80,504
1 comentário
I also have a Vizio M Series TV that will decide on it's own to change the volume. Sometimes it will turn it all the way down. My "Volume Levelng" feature is turned off. I have two Vizio TVs that have this issue. Your suggested 'fix' does NOTHING to solve the issue.
por abarisdigital
