TRS 3.5 mm jack weird contact issue
So the problem is complex it has 2 parts:
First:
When I plug it in, there is no sound BUT when I press it sideways (only the plastic not touching the cable) it gives me sound.
Second:
When it gives me sound the above mentioned way the vocals are messed up so I thought it might be a cable break BUT when I plug it in halfway it gives me perfect sound...except for it is mono (Left channel in both sides)
--my guess--
So I have no idea about the first one. Is it not a standard 3.5mm? Is there a 3.49 mm jack that I have not been aware of?
The second one is obviously when the T and R part of the jack touches the left output of the female jack, but when I pulg all of it in, both are distorted. How is this possible?
--what I have tried--
other female jacks
other male jacks in thoose female jacks
cleaning the jack (even though it's already clean)
looking for cable breaks
crying
Esta é uma boa pergunta?
Hi, What are you plugging it into?
You say that you have tried other "female " jacks (sockets). Does this mean that you have disconnected the socket from whatever it is attached to , connected a new socket and then plugged your headset into it and it is still the same?
Also a bit confused. Product details show USB interface connection with 2.5M cable?
por jayeff
by the female sockets I meant my phone, computer other computers etc.
No Idea about the usb thing, I couldn't find the jack version on the internet either, but it has a jack on the box, the manual and ofc the product itself (-.-).
por mrwayash
Hi
Is it a 4 pin plug or a 3 pin plug?
por jayeff
It's TRS as I mentioned in the title so 3
por mrwayash
Hi,
Apologies.
Well plugging into your phone for example needs a 4 pin plug as the socket caters for a microphone as well, not sure about pc as it could vary.
Here is an example to overcome the problem if no microphone needed.
http://www.dx.com/p/3-5mm-audio-adapter-...
por jayeff
Exibir mais 6 comentários
