Ir para o conteúdo principal
Hands-free voice-activated device by Amazon powered by Alexa Voice Service. Model S04WQR.
14 Perguntas Visualizar todos
Alexa can't set alarm for me. Says is a problem when I ask.
In past could set alarm by asking Alexa to set alarm for a time specific. Now she says alarm set...then few seconds later say problem setting same. Help, thanks and Happy New Year.
Esta é uma boa pergunta?
Pontuação 4
1 comentário
I have 8 echo dots covering 3 generations...suddenly today only the first gen dot is able to understand what a timer is. The others reply with..."Hmmm, I'm not sure". Oddly, when I ask them how to set a timer they respond with, "say something like, Set a timer for 5 minutes", but when I do, I still get, "Hmmm, I didn't understand" or" I don't know that one".
por
Adicionar um comentário
5 respostas
Pergunta mais útil
I had the same issue. My Echo Dot was connected to wifi and would interact and tell me the temperature.
Every time I tried to set an alarm it would take the command, and then about 5 seconds later respond and say it had a problem setting the alarm.
After reading this post I decided to try power cycling it. That seems to have worked - it took the command. It also is showing up in my iPad Alexa app.
Problem solved.
Esta resposta foi útil?
Pontuação 3
There is a problem connecting to the amazon alexa service. You should check if it is connected to wifi, and if so, if the wifi is connected to the internet.
Pontuação 1
Sometimes Alexa enabled device like mobile app does not support alarms or timers.
Pontuação 0
Open the Alexa app. On the side menu, go to reminders and alarms, click the alarm tab and push the button to the on position
Pontuação 0
Just go to settings and choose factory reset option.
Follow the instructions and your problem will be solved…
Pontuação 0
Adicionar a sua resposta
Larry Hirsch será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 100
Duração total: 22,286
