Error E100 - No Disk Drive In Console
Can you run an Xbox One without a disk drive? I just want to make sure this is normal. I am getting an error at start up [E100-XXX-XXX-XXX] (The X's representing random numbers)
Also, I have been hearing mixed results from family and friends on getting a new disk drive. I am being told that you have to have the original drive of that xbox in order for you to replace it, but I don't have the original drive at all. (I bought it online as a unit without a hard drive or a disc drive - [I reformatted and coded a 1tb hard drive which does work - I tested it out on another system, and reformatted it again just in case i get any more errors on my current console]. Can I get a disk drive online, and would that work?
Esta é uma boa pergunta?
1 comentário
“This indicates that there was an issue while updating your hardware and that you'll need to submit your console for a repair.” E100 appears to be a serious issue, however, some users are saying that they eventually got it fixed and were able to install updates successfully.
This May Help,
Peter
por Antonios Grift
