Ir para o conteúdo principal
Repair guides and disassembly information for laptops manufactured by ASUS.
2518 Perguntas Visualizar todos
Asus laptop not turning on and no lights.
My Asus K55V laptop not turning on or no lights blinking when connected to power adaptor or with battery.
I shutdown and put it in charge overnight and morning it is not getting On.
Plz help....Thankz in advance ☺
Esta é uma boa pergunta?
Pontuação 2
9 comentários
Did you do anything to the previous night that might affect it? Anything at all? Did you rock it, sock it, or pick it up and drop it? Did you install any software?
por
No i didnt. Juz put it on charge.
por
I couldn't get mine to turn on and the battery isn't removable. Tried many things, then decided to get creative. I made this up, and it worked: attach HDMI cable to the laptop and to tv, turn on tv. Then press and hold the laptop on button. It took a few tries, but it worked.
por
Why is it not working I don't understand I've got a new charger an all of a sudden it just won't come on
por
Attention Purchasers of ASUS Rog Strix GL502VS and GL502VSK If you purchased the laptop in the United States Between May 4, 2014 and November 19, 2019. Then you are entitled to Cash Payment of up to $110, or Credit Certificate of up to $210 from a Class Action Settlement. The Laptop can cause physical discomfort to people and/or diminishing the Laptops’ performance by power draining of the battery even when plugged in. You MUST file a Claim online at website below by April 03, 2020. https://www.asuslaptopsettlement.com/
por
Exibir mais 4 comentários
Adicionar um comentário
3 respostas
Pergunta mais útil
Oh, I have this other solution to make your laptop ASUS on. (Based on my experience lol)
I used my laptop and do whatever and suddenly my laptop was shut down. I charged it and wait until the battery is full (The lights indicated)
After I plugged out the charger. I open my laptop and it didn't turn on.
So, starting that time, I didn't use my laptop for how many days, I guess 3 days or 4 days.
And I decided to open my laptop and boom! My laptop turn on.
That was my experience, and I'm so gladly that my laptop is baaaaack. ☺
Esta resposta foi útil?
Pontuação 1
3 comentários:
what if it's not charging too?
por
Hello everybody here, The Asus laptop that I have been using is not turning on, the battery is dead, a few days ago, the laptop died, I got if fixed, turned it on, the same, laptop won't turn on. Does anybody have suggestions?
por
Think I’m going to stop buying ASUS this is the worst experience I’ve ever had with a ASUS machine. I bought my daughter a visiobook for college what an absolute nightmare. 3 months after Christmas and it stopped charging sent it off to be fixed and it returned working not even a year in and back to the same old problem plug it in won’t charge. Go to the help pages and they tell you to do a hard reset and try again then it goes from one extreme to another check your hardware and drivers ! How can I check my hardware or drivers if I don’t have power! Beggars belief.
por
Quick fix hold your Ctrl and alt plus your escape and power button til the power button stops blinking or shuts off completely then wait a minute or so and then power on as usual. Should turn back on.
Pontuação 1
3 comentários:
Thanks worked first time :)
por
Cheers, this worked for me too !!
por
it worked! but why though? why did that happen?
por
Please check if the AC adapter connector is loose (marked in the image below: A-power cord plug / B-outlet side plug / C-NB side AC jack), or you can try connecting to different outlets. Please check if the adapter or cable is damaged. If there is any damage, please contact ASUS service center for further information
Regards,
Will
Pontuação 0
Adicionar a sua resposta
Sreejith SivaGeeth será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 25
Últimos 30 dias: 95
Duração total: 76,478
