Ir para o conteúdo principal
My phone won't turn on, just a red LED when charging.
As the title says I have a Huawei Ascend G700 and when I try to turn it on it just does nothing: black screen, no sound, no vibration. If I plug it to the power it just turns on a red LED and nothing more...
I tried removing the battery and plugging it to the power but just gives the red LED again.
I also tried following some guide to restore the stock rom but it won't even recognize when the phone is plugged to the PC while doing it (I hoped it was a software problem and I also installed all the proper driver for CDC and the VCOM preloader).
I don't know what else to do and I seriously suspect the problem is hardware, I hope you guys can help me with this. Thanks in advance!
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
I have the same phone and the power button on mine starts to work unreliable. The sparepart is about 10€ on eBay. Maybe that's where the problem comes from (if you still own the device).
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Emmanuel Sacco será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 6
Duração total: 723
