Ir para o conteúdo principal
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
572 Perguntas Visualizar todos
Logic board replaced, won't power on.
Liquid damage. Upon disassembly, found logic board burned where hard drive cable connects. Replaced logic board, replaced hard drive cable, reassembled. Connected to power, and it won't turn on. I see the battery indicator, but nothing happens when the power button is pressed.
I found another thread that discussed the possibility of the charger inlet daughter card being faulty, and that you could jumper two solder points to test, but it was a different model macbook (an older one I believe), is that possible with this one? What could the problem be?
I'm new at this, but I was disgustingly meticulous with disassembly and reassembly.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Pergunta mais útil
Look for blackened and or burnt areas or components. Get the battery out ASAP
Esta resposta foi útil?
Pontuação 1
4 comentários:
Did it just burn the cable or the board also?
por
Here's a replacement hard drive cable, maybe that will suffice: MacBook Unibody (A1278) Hard Drive Cable
por
Unfortunately the board looks pretty toasted at the point where the cable connects, it will need a new cable as well though.
por
Replaced logic board and the cable, won't power on: Logic board replaced, won't power on..
por
Adicionar a sua resposta
Patrick será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,882
