Pular para o conteúdo principal
GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
184 Perguntas Ver todas
Home button and 30pin not working - ribbon or charging IC?
The iPad I'm looking at had occasional USB connection issues a few weeks back before it stopped charging completely(the home button was completely fine before that). Hitting it from the back while it's plugged in sometimes power it long enough to make it turn on or make a charging sound.
Is there a way to tell if the problem stems from the 30pin/home button ribbon or the charging circuitry on the logic board without taking it apart?
Respondido! View the answer Também tenho esse problema
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 Solução
Solução escolhida
Have you tried a new 30-pin cable? Perhaps your cable is old or damaged and not making a good connection.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Honam1021 será eternamente grato(a).
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 34
