Why is my rpms running high when I start to accelerate slow?
My 2005 Nissan Sentra runs great except when I start to accelerate to get speed, my rpms rev up and you can hear it. I try to coast as much as possible. I only drive no more then 5 miles a day no faster then 40 mph.
Respondido! View the answer Também tenho esse problema
Esta é uma boa pergunta?
Pontuação 0
Comentários:
I have a 2015 chevy impala ltz that all of a sudden the engine revs too high when I take off or when the trans shifts. sometimes it revs as high as 5000 rpm
por
Adicionar um comentário
Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
Visite Nossa Loja
3 Soluções
Solução escolhida
I can't be very specific but in general, this symptom usually points to a problem with the transmission, or if you have a straight shift, it probably means the clutch is slipping. On automatic transmissions, the shifting is often done by hydraulic pressure based on engine speed. If the system fails, it may require high engine speed to shift to the next gear or it may not shift to the next gear at all.
Esta resposta foi útil?
Pontuação 0
Resposta Mais Útil
@dwdrummerswife , Christi, You should stop driving the vehicle if transmission is indeed slipping, as you are going to cause extensive damage and expense. Check the transmission fluid level and fill to recommended level if low. If fluid level OK, take vehicle into a good shop, have Tech. take a look, diagnose and estimate repair. Link below will show how to check transmission fluid level in automatic. Good luck.
I hope this helped you out, if so let me know by pressing the helpful button. https://www.carcarekiosk.com/video/2002_...
Pontuação 2
Comentários:
Mine too is doing the same thing, but it's a 2005 Renault Clio 1.2 litre with a standard gearbox
por
My car is doing the same Just got a transmission put in 2 days ago I drive freeway everyday If I go past 50 mph the rpm is over 4,000 you can hear the motor revn up loud Does this mean the computer just doesn't recognize there's a new transmission yet
por
I've replaced the coil packs on my plugs and it fixed the problem. No longer does it and sounds allot better. Try that before taking it to a shop first.
Pontuação 0
Comentários:
Hi,just overhaul my automatic transmission,high revivving wen drving.
por
And takes long to change gear,mech says must run it in.
por
Adicionar a sua resposta
Christi será eternamente grato(a).
Visualizar Estatísticas:
Últimas 24 horas: 160
Últimos 7 dias: 889
Últimos 30 dias: 4,628
Todo: 50,299
