Ir para o conteúdo principal
The Macintosh Color Classic was the color all-in-one Mac in the early 1990's
10 Perguntas Visualizar todos
I see some empty slot on the logic board. What's it for and ..
I see some empty slot on the logic board. What's it for and can I stil find one somewhere?
The mac is working fine. The old caps are still in place but I believe is has not had many working hours. So I am not planning to replace them right away.
I am momentarely blasting the cover with thickened waterperoxide and UV licht. It is getting it's original coulor back. If someone wants to know how that goes just ask me.
I ordered two memory slots and a video upgrade card and a battery for 56 euro total but I have to pay 50 for postage too. So is any body has tips they want to share, I am all ears.
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Here's the full specs of your system: Macintosh Color Classic
por
It reads (4) Socket for the optioneel 68882 math coprocessor
so your answer is good. Thanks
por
Adicionar um comentário
1 resposta
Solução escolhida
I think you're talking about the Processor Direct Slot (LC-PDS)
Esta resposta foi útil?
Pontuação 3
4 comentários:
@danj is this different from a NuBus slot? I don't remember.
por
Yes, it was proprietary to Apple.
If I remember it came out just a bit before NuBus and was intended to be for the small systems. There where two versions of the slot depending on the PowerPC chip in the system. Again if I remember correctly the first was an 8bit bus and the second 16bit wide bus.
por
I want to post a photo of the motherboard but I don't see that option. But I found this pictur online https://www.google.nl/search?q=motherboa...
It is the empty square in top left from the middle
por
Here's a better link: Old Computers - Then click on the motherboard to get the full rundown
The square socket is for the optional 68882 math coprocessor
por
Adicionar a sua resposta
Rufus Kohn será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 10
Duração total: 237
