Ir para o conteúdo principal
Late 2011 model, A1278 / 2.4 GHz i5 or 2.8 GHz i7 processor.
591 Perguntas Visualizar todos
Is this hinge a problem or not?
macbook pro late 2011 13 i nch
today i found out this : https://www.youtube.com/watch?v=nkWJ_T5I...
is this a problem? i looked inside i saw the hinde rod move back and forth
the hinge is stil steady tho at all angles the screen doesnt drop (the magneets pull it down tho when super close)
only thing is when i move it from when its almost close position it makes a slight noice but nothing anoying since that position isnt used alot
should i replace the hinge or not?
does this involve removing the glass? my glass panel does need a replacement so that can be a combined repair if needed
if wanted i can shoot a inside video tomorow
Esta é uma boa pergunta?
Pontuação 0
2 comentários
ok wil this fix it? i wil take it apart tomorow to paint the under site i wil take a look
por
Paint? just how beat up is his machine? How about a hard case?
http://www.ebay.com/itm/262237889185?_tr...
por
Adicionar um comentário
1 resposta
Solução escolhida
See step #13 of this guide. Put it in place and tighten the screws.
MacBook Pro 13" Unibody Late 2011 Display Replacement
Remember, "if it ain't broke, don't fix it".
Esta resposta foi útil?
Pontuação 4
Adicionar a sua resposta
raymond1212 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 138
