Ir para o conteúdo principal
Sony Xperia M4 aqua was released 2015, June. With a Size of 5.0 inches, it was operated in Android OS, v5.0.1. Sony Xperia m4 Aqua has internal of both 8 GB, 2 GB RAM/ 16 GB (E2306) And it has 13 MP Primary Camera and a 5MP Secondary Camera. This phone has a non-removable Li-Ion 2400 mAh battery.
37 Perguntas Visualizar todos
I can't make calls, why?
Hi everyone,
I need help with my phone (Xperia Aqua M4) because I can't hear anyone I call since almost 2 months now (I have this phone since August 2015). I can listening music if I use my earphones and the speakers works for make calls. But the primary function of my phone doesn't work. I tried to clean the orifices with alcohol 70% and a Q-tip. I found a lot of dirts (I work as a gardener, so). But that was not effective.
Any ideals?
Thank you for your help,
Alexe
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi Alex,
If the only speaker not working is your earpiece speaker, it may need replacing.
There are quite a few videoes about on YouTube and a guides here on ifixit to help.
But opening the Xperia will more than likely void any water resistance that phone has, as it is held together by double sided adheshive.
Esta resposta foi útil?
Pontuação 3
1 comentário:
Hi Ged,
Thank you for your answer!!
I will give a try! That will be nice if that working well. Maybe I will be able to find double sided adhesive on asian market! A lot of store told me they can't repair it because the screen risk of cracking.
por
Adicionar a sua resposta
Alyrxc será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 1,302
