How to replace a Samsung HDMI port
My HDMI port on the back of the tv is loose and the cable does not stay secure. How can I replace the port?
Esta é uma boa pergunta?
Hello Bill,
Open up the tv bij unscrewing the BACK PLATE.
Now carefully remove the BACK PLATE until you see the LOGIC BOARD(the one with the connectors in it).
Next you will have to check if the HDMI port is separated or is still making contact with the LOGIC BOARD.
If it is separated you will have to solder it back to the LOGIC BOARD(every pin on its own).
If it is still making contact you will have to secure it to the LOGIC BOARD with some non conductive tape.
Good Luck!
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 16
Duração total: 4,668
