Ir para o conteúdo principal
2.3L 4cyl or 3.0L V6, 6th Generation
425 Perguntas Visualizar todos
Dashboard HAZARD LIGHT is out.
How do I replace the tiny light bulb for the HAZARD LIGHT SWITCH on the dashboard? I know how to replace the bulb for the clock on the dashboard but how do I replace the bulb in the button on the dashboard that is used to turn on the HAZARD LIGHTS?
Thanks again.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Solução escolhida
@mconley ,I believe I posted how you were to change the clock bulb. From that video, remove the hazzard button / take it apart and change the bulb. Be adventurous, You can do it. Check the vids may help. Good luck.
https://www.youtube.com/watch?v=gjSLqpHF...
https://www.youtube.com/watch?v=P3TqheRs...
https://www.youtube.com/watch?v=MyjDCdK-...
Esta resposta foi útil?
Pontuação 1
Check out this YouTube video
https://youtu.be/MyjDCdK-kjo
Update (12/13/2016)
Okay, sorry about the clock video.
I checked out this website and got a diagram for replacing the light to the hazard switch.
http://www.hondapartsnow.com/parts-list/...
It looks like there are 2 types of bulbs depending on the part you have (Part 11). You will have to take a look. Hope this helps!
Pontuação 0
That should work for the CLOCK but NOT the HAZARD LIGHT (the triangle shaped red light on the dash to the left of the clock.
Thanks anyway.
Pontuação 0
Adicionar a sua resposta
Michael Conley será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 11
Duração total: 1,396
