Try with a different battery.. A simple way to check the integrity of the battery is to remove it entirely and try plugging in the laptop. If the laptop powers on properly, the problem is likely a bum battery.
Breaks, Burnout, and Shorts
Feel along the length of the power cord, bending and flexing as you go, to check for any kinks or breaks. Check the ends for any broken connections, such as plugs pulling loose or spots that may have gotten chewed by a pet or caught in a vacuum cleaner. Inspect the AC brick. Is it discolored? Are any parts warped or expanded? Give it a sniff—if it smells like burnt plastic, that's likely where the trouble lies.
Several internal parts can cause problems when they malfunction or fail.
Common culprits include a faulty motherboard, Several internal parts can cause problems when they malfunction or fail.
Common culprits include a faulty motherboard, wonky logic boards, damaged charging circuits, y logic boards, damaged charging circuits
Please help me I Wood really apreciate it thank you
por Elena
