Ir para o conteúdo principal
O iPhone 5C da Apple foi lançado em 10 de Setembro de 2013. O reparo deste smartphone é similar aos modelos anteriores. Você precisará de chaves de Fenda/Philips/Torx 0.8 e espátulas de plástico. Disponível nas versões GSM ou CDMA / 8, 16, 32 GB / Branco, Rosa, Amarelo, Azul e Verde.
1233 Perguntas Visualizar todos
Doesn't wake up after sleep mode
Hi, iPhone 5c doesn't wake up after some time in sleep mode.
As long as it's in wake mode everything works normal. But when I press the sleep/power button it won't wake up after 5-10 minutes. Within 5 minutes it will wake up... After 5 - 10 minutes it doesn't turn on until I boot it up again .
There is nothing wrong with the buttons, screen or battery. I also can't find shorts.
Any ideas? Thanks!
Esta é uma boa pergunta?
Pontuação 1
1 comentário:
No water damage. software works and doesn't show Strange error in log files.
What happens inside the circuit if you press the sleep button? What power/data lines/chips shut down and have to start up once you press the power button again to wake up...
That's what I like to know..
I have the schematics.
por
Adicionar um comentário
1 resposta
Was it water damaged? Have you tried hard reset? This is known issue when the power flat was loosing contact, but you say it isn't hardware issue...
If software doesn't work, I would bet on motherboard problem...
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Gordon De Clerck será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 117
