iMac wont power up, replaced power supply. Bad logic board?
Hello, I have an iMac A1418 . When I press the power button I get no chime, no hard drive spinning up, no fans going. I suspected faulty power supply so I ordered one and replaced it.
I have not plugged the screen in yet, just all the new power supply cables to test but I am still not getting any response from the computer. Things I have tried below.
1. Turned of machine and unplugged all cables. plugged just the power cable back in and tried turning on, nothing.
2. Tried using a different power cable
3. Tried using a different outlet.
4. Replaced with new power supply.
I was informed that their should be diagnostic led's that are next to the ram slots? Would this then mean that I need to disconnect the logicboard to access behind it where the ram is so I can view the diagnostic led ?
again the computer does absolutely nothing when attempting to power on. No chime, no fans, hard-drive does not spin up nothing.
Any help is greatly appreciated.
Esta é uma boa pergunta?
2 comentários
No te LED are not next to the ram. You see the LED without disconnecting the logic board. They are right in front of you. A bit lower then the RAM. (see pics in my question)
por Mattis
Hi
I have the same issue with my imac 2011. Were you able to get yours fixed?
por Neilson
