Ir para o conteúdo principal
Third generation of iPad, featuring 4G capabilities, released on March 16, 2012. Model number A1430. Repairs require heat and careful prying.
106 Perguntas Visualizar todos
iPad will not sync with iTunes shows error 27 then 14 therafter
I have a iPad 3 4G with the 30 pin connection port that I purchased new from Best Buy a little over 4 years ago for almost $900. After my last update around 6 months ago iPad began to throw errors (27 &14) when doing a restore while connected to iTunes. After procrastinating for a while I called Apple Support and they did some troubleshooting. Apple tech made sure I had the current iTunes version. I tried multiple data cables that charged my kids' iPod without fail. After Apple Supports failure of solving the issue tech arranged an appt at the nearest Apple Store. Same issues occurred at the Apple Store with tech's MacBook Pro and his own data cables. Tech stated that the error 14 indicates a faulty charging/ data port. Apple Store said they could not fix and best option was to trade in my iPad and they would give me the same iPad just in new condition for $300. I figured for the advancement in the processor it probably wasn't the best decision. My iPad has never been wet and very seldom used compared to most. I mostly paid bills, emailed, & surfed the internet. Can this iPad be fixed? What is my best course of action? Thank you for reading & taking the time to answer. Happy Holidays!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Solução escolhida
It's hard to get by the accent but here's a video on fixing error 27: https://www.youtube.com/watch?v=vAvawCmB...
Esta resposta foi útil?
Pontuação 3
Attempt to DFU Restore the iPad but you may need to do this three times. The process for your iPad DFU is easily searchable. as well make sure you have a known good charger and cable some of the non apple cables are not as reliable
Pontuação 0
You can check the solutions and methods at here: How to fix and solve Error 27 Code Problem
Pontuação 0
Adicionar a sua resposta
Brian Prince será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 22
Duração total: 4,155
