iPhone 6s proximity sensor not working after screen replacement
I changed my iPhone 6s screen and after changing it the proximity sensor doesn’t work fine. I record a voice memo and try to put my finger on the top of the screen (just above the headphones) and it doesn’t work which is the normal place of the sensor. I put my finger just an inch down (exactly where the display starts) and the sensor works but much less sensitive than the normal and in the wrong place. I made sure that the sensor is placed perfectly in place, i also tried changing the screen (from the same supplier) and also tried changing the front camera flex and I still have the same problem.
Esta é uma boa pergunta?
2 comentários
Have you solved the problem? I Have the same.
por Kim
try to paint that sensor window with a sharpie, see it might help.
in my case it started working only after i did a full reset through out DFU mode.
non-original screen , original flex cable ( sensor )
por bicu_cristian
