Laptop shut down, won't turn on anymore.
Month ago while on my computer, it's black out.
Shut itself off, and i have not been able too power back on.
Can i refurbish this unit?
Esta é uma boa pergunta?
Does the battery hold a charge ? Did you get a BSOD ? Did it give an error message when it shut down ? do you get any responce from the computer when you try to start it like post beeps or fan noise or hard drive noise . do you get any leds lite?
Here are some things to try First do a static discharge ,remove the battery unpug the power cord then hold the power button down for 60 seconds then plug it in and reinstall the battery and reboot . If this gives no Joy then try connecting to an external monitor . if this doesnt help try removing one dimm of memory at a time and booting to see if theres issue with the memory. If theres only one bar then find another stick of memory to see if that works . If one dimm of memory fails then the laptop will not boot. Try these and get back to use with your results so we can further diagnose your laptop
Esta resposta foi útil?
*Take out the battery,
*Remove main supply,
*Hold power button down for 30 secs,
*Put only power supply in, do not put battery in
*Turn laptop on
*Put the battery in.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 5,670
