Vertical lines appeared on my iMac after hdd to ssd swap
Hello
I got vertical lines on my iMac 27 inch A1419 after a hdd to ssd swap. I can't really send the iMac to a repair center and was wondering if it is more likely to be the lcd cable or the lcd panel itself that has been damaged ? Here is a photo of the problem :
https://www.dropbox.com/s/mlyowrfupf07xy...
Thank for your help.
Esta é uma boa pergunta?
2 comentários
Did you make sure to put the correct screws in the right holes? It would surprise you how much that can affect the performance of the machine.
por Ben
Can you give us your model info as the A1419 covers quite a few different systems. If you don't know lookup your systems SN here: EveryMac - Lookup then paste the systems URL here so we know which one you have.
por Dan
