What should I do if my battery won't charge?
My battery isn't accepting a charge at all, and the cable is plugged in.
Esta é uma boa pergunta?
If the device is not charging while the the cable is attached to both a power outlet and the charging port on the device, the battery may be fairly easily replaced by unclipping the old battery from the motherboard and replacing it with a new battery. If this does not solve your problem, you may need to replace the micro-USB port located on the motherboard which requires more work.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 733
Student, being worked on by hardworking students
por L Pfaff
