Need a diagram of 91 chevy c1500 steering column
Steering wheel is very loose . Took it apart and tightened it up and put back . Wll not go back together. Would like a diagram of steering column.
Esta é uma boa pergunta?
kpgklm, The links below will show exploded view and vids on steering column to aide in your repair. Check the attached links,instruction and guides, Good luck.
http://www.steeringcolumnservices.com/ex...
Esta resposta foi útil?
L Pfaff came thru with flying colors.. Very fast response with the info I needed. Thank you so much ! Still good people around !
kpgklm, thanks for the response, if it was the answer you needed vote it up, Thanks.
Últimas 24 horas: 1
Últimos 7 dias: 16
Últimos 30 dias: 45
Duração total: 15,463
1 comentário
Make sure bearing is assembled properly just behind steering wheel
por p_buchwald
