Ir para o conteúdo principal
The Fitbit Surge was released in 2015 and is identifiable by model number FB501BKL. This is a smartwatch that is capable of monitoring your heart rate, pace, elevation, and distance.
23 Perguntas Visualizar todos
Why won't my battery charge?
My battery doesn't seem to be charging. I think it is plugged into the charger properly, what else could I do?
Esta é uma boa pergunta?
Pontuação 4
Adicionar um comentário
3 respostas
Pergunta mais útil
My fitbit is not charging.
Esta resposta foi útil?
Pontuação 2
If your charging cable is securely plugged into your device and it is still not charging, the USB port may be faulty. Test your computer’s USB port by inserting a different device into the port and checking it if is functioning. If the port is faulty, plug your charger into a different port or a different computer.
Pontuação 1
I don't know . Someone tell me what to do .
Pontuação 1
1 comentário:
I have found an easiest way to charge fitbit charge 2.. check it out..
https://technoradars.com/how-to-charge-f...
por
Adicionar a sua resposta
Angela Pitts será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 1,479
