Ir para o conteúdo principal
a1549 won't register with any network
I have one that is stumping me. iPhone 6, a1549, won't register on any network no matter what SIM I use. Tried using a VZW, ATT and Sprint SIM and it wouldn't activate. Popped in a Tmo SIM and it activated. OK...so its a Tmo. I pop a Tmo SIM in with active service and it won't register on the network. Tried rebooting, reinstalling, banging it on the counter, all the usual steps.
What am I missing here? The phone works, the SIM works. I'm half tempted to believe that the phone is locked to some weird network but when I run it through our unlock service, its already unlocked.
HALP?
And just like that...it works. I didn't do anything to it other than open it to see if I could see anything.
I really do hate iPhones.
Esta é uma boa pergunta?
Pontuação 0
5 comentários
Hmmm....ran a cellular network test app and the phone isn't seeing any cellular networks. SIM registers just fine, IMEI shows up.
This is an odd nugget.
por
Hi,
Know nothing about iPhones but thought this may be of interest to you.
iPhone 6 cellular antenna location/replacement
Expand the comments above the chosen solution for more info.
por
Thanks. I'm not leaning towards anything hardware on this one.
por
Have you checked that it does have the correct time and date????
por
Yea...even toggled auto update and rebooted.
IMEI check came back and its for sure Tmo locked. Sooooo.....looks like it might be hardware.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Don't rule out hardware. Loss of cellular connection is obnoxiously common on the i6. The antenna switch l
(rf5159) has gone out on a few phones I've seen. Any of the antenna connections could be loose or there is some kind of debris between them. Has the phone been disabled and reassembled before?
Esta resposta foi útil?
Pontuação 2
1 comentário:
Never been taken apart, which was why I was trying to eliminate software first. I think I've done that.
Thanks for that part number. Looks like an easy enough swap.
por
Adicionar a sua resposta
Josh W será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 179
