Ir para o conteúdo principal
Irrational Battery after Screen/Display Change
Hi there,
I changed the broken display of my iPhone 6s and ever since then it behaves irrational. The battery is drained completely after less then 4 hours of use. Sometimes, after fully loading the phone, I unplug the power chord - start up a program and the display goes dark with the "load battery" animation. Then it shuts down. After some seconds you can power it up again with the power button and it will work just fine with showing full capacity on the battery.
I already reopend the phone and checked all the connections. Nothing to be seen.
On a side note: the back side on the top, around the camera modul tends to get a little warm, well warmer than my hand. You can feel the warmth.
It is not an ifixit replacement display since ifixit could not deliver when I needed one ...
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Use the repair program:
https://www.apple.com/support/iphone6s-u...
Esta resposta foi útil?
Pontuação 3
Pergunta mais útil
I recommend replacing the battery.
Batteries can go bad especially when the phone is dropped and the screen gets cracked.
Sometimes the glass fragments from the screen manage to go inside the phone and cut the battery causing battery acid to be released which is not a good thing.
A sign of this is when you see White marks on the punctured area of the battery.
Pontuação 3
Adicionar a sua resposta
Anselmbe será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 62
