Ir para o conteúdo principal
Released alongside the Wii console on November 19, 2006, the Classic Controller is a simplified, non-motion controlled remote for the Nintendo Wii, geared toward classic gamers.
2 Perguntas Visualizar todos
What type of screw is used in the end connector?
On the plug that connects this controller to the other controller, There is a clear plastic piece that is held on with two screws in a triangle shape. I need to remove this piece but I can't find a screwdriver with the correct tip to use. What size tip do I need?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Sounds like a tri-wing screw. Would you post a photo?
Tri-point Y1 Screwdriver
Tri-point Y0 Screwdriver
The Y0 & Y1 are included in this set:
[produto vinculado ausente ou desativado: IF145-028]
Imagem de Tri-point Y0 Screwdriver
Produto
$5.49
Imagem de Tri-point Y1 Screwdriver
Produto
$5.49
Esta resposta foi útil?
Pontuação 1
2 comentários:
I see I can insert a link but I don't see how to add a photo to the post. The Y0 Tri-point was correct. Thanks!
por
bryangarmon you can only add images to answers or question, not comments. Use this guide Adicionar imagens a uma pergunta já existente to add images.
por
Adicionar a sua resposta
bryangarmon será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 440
