Ir para o conteúdo principal
Guides for the Wi-Fi version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
220 Perguntas Visualizar todos
Backlight not working after water damage!
So, for some reason, I got bored and put my iPad in a sink full of water and pushed on the screen. I guess boredom does a lot to you. I tried to turn it off, but for a while the power button wouldnt work, and kept turning back on. The backlight would sometimes flicker and now it doesn't work at all! Can someone overcome my stupidity and help me?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
As you know water and electronics and electricity are not a good mix.
The water causes corrosion and provides circuit paths for the electricity which were not in the tablet's operating design and could damage the components.
First do not turn on your tablet and then you need to remove the battery as soon as possible from the tablet to minimize further damage.''
Then you need to dis-assemble the rest of the tablet and clean all the affected parts using Isopropyl Alcohol 90%+ to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% and is not as effective. If you do check the label to verify the amount
Here is a link that in general, describes the process.
Electronics Water Damage
You may have to replace the battery as it is very hard to recover a battery from water damage.
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the tablet might possibly work correctly again.
Here is a link to the ifixit guide(s) for repairing your tablet.
iPad Mini 2 Wi-Fi
If this process seems too daunting, take your tablet to a reputable, professional computer / phone / electronics repair service and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Esta resposta foi útil?
Pontuação 3
2 comentários:
I have a warranty on it, but I wanted to see if there was some sort of quick fix for no backlight.
por
Hi, Does your warranty cover water damage then? Maybe you should check and make sure. Besides opening the device to 'fix' it usually voids any warranty.
por
Adicionar a sua resposta
Dylan McLaughlin será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 852
