Why won't my device turn on?
The laptop won't turn on. Nothing happens when I push the power button, and leaving it plugged in has no effect.
Esta é uma boa pergunta?
Before you do anything, first check to see if the power cable is plugged fully into the wall as well as into your computer. If this works but the computer doesn't charge fully or dies quickly, then see the guide on how to replace the battery in your computer. If this doesn't work, you may need to buy a new power cable.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 106
