Ir para o conteúdo principal
Repair information for the 4th generation iPad. Released November 2, 2012. Model numbers: A1458, A1459, and A1460.
408 Perguntas Visualizar todos
Needs to activate with iTunes but Powerbutton doesn't work
Hey Guys!
Have been using this site mostly to read and find answers but now I do have a customer who came in with an iPad model: A1458. The screen is cracked but the biggest problem is that it is deactivated due to his children tried to open it to many times with the wrong passcode. There is no biggie. You do just connect it to iTunes and put it in DFU mode and restore it as long as you have the iCloud account. BUT the power button doesn't work.
Any tips of what I can do?
Thank you
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Solução escolhida
You could try and bridge the contacts with a copper wire..that would act the same as pressing the home button
Esta resposta foi útil?
Pontuação 2
I'm a little slow but...why wouldn't you fix the power button? It should be a few dollars in parts and a half hour of your time.
Pontuação 2
1 comentário:
I agree, the power button should be fixed.
por
  • Let the battery die
  • Fix the iPad
Pontuação 1
Adicionar a sua resposta
Albin D será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 74
