Ir para o conteúdo principal
The HP Compaq 2510p, model number "GM651AW" and was released June 2007. It features an Intel Core 2 Duo ULV processor and 12.1 inch display.
4 Perguntas Visualizar todos
My laptop won't power on.
I press my power button, and my computer wont turn on. There's no lights when the battery is plugged in either. Does anyone know whats wrong?
Esta é uma boa pergunta?
Pontuação 3
1 comentário
Student question
por
Adicionar um comentário
2 respostas
Solução escolhida
You can try doing a static discharge . Remove the battery and unplug the laptop so there is no power to it at all . Then hold the power button down for 60 seconds this drains any residual power from the memory and allows a clean boot. Then reconnect the battery and power and boot the computer normally. If this gives no Joy test your power adapter to see if there is an issue there .If the adapters not providing power it wont charge the battery Hope this helps
Esta resposta foi útil?
Pontuação 4
Your battery may be defective. However try removing the battery for 60 seconds and see if the problem persists.
Pontuação 0
Adicionar a sua resposta
Dan Champagne será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 2,453
