Ir para o conteúdo principal
12.1" business laptop released in June 2012 by Lenovo. This laptop uses multiple product numbers, which vary based on configuration.
21 Perguntas Visualizar todos
Why can't I see any content on my screen?
The thinkpad is powered on and working correctly but the actual content on the screen isn't visible.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Not seeing anything on your screen can be due to many issues. The first issue can be that your backlight is to dim. In order to check this Press F6 to increase brightness and F5 to decrease brightness. If this doesn't do anything try charging your laptop or replacing the battery. Lastly, if none of this works try replacing the screen. Check out this repair guide to know how to do things: Lenovo Thinkpad x230 Screen Module Replacement
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Lino Virgen será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 104
