miswiring message in my stereo.
When powering the radio, there's a stereo message "miswiring, check wiring then power on"?
Esta é uma boa pergunta?
Try looking on the troubleshooting page under faulty wiring connections.
Esta resposta foi útil?
I got this error after the unit had been installed for 2 years. I tried many ways to troubleshoot the problem, eventually ending up with nothing connected to the unit except for the black ground, the red power, and the yellow continous power. Still, the message persisted.
I removed the deck and looked at the back. There is a bank of wires coming from the circuit board that had visible corrosion bridging the gap between some of the wires. I scraped this corrosion off, and put everything back together and the system works.
It seems that Kenwood didn't make this marine deck to be around a humid environment. I'm wondering if there is a non-conductive coating (epoxy?) that I could coat this circuit board with to prevent reoccurance. Any ideas?
I have the same error message.
I’m going to do this next time I’m at the marina. Thank you in advance if that solves the problem
1) miswiring, please check wiring appear on kenwood player
2) pull out the main power connection.
3)press button 3 and 6 at the player then connect back the power
4) when DC error appear, press button 1.
5) when DC1 OK appear on the display, press button 2 and wait till DC2 0 display on screen
6)Turn off the player den turn back on
7) player is ok.. no more miswiring appear.
Here's a link to see how it's done!
I’m getting the same message. I have unplugged everything including disconnecting the battery. I even removed the face and held the rest button. It is a single din, no amp and only two speakers. Spent hours trying different things. I’m stumped! Installed it new a a little over two years ago. Any help would be appreciated!
mine was faulty cd player removed from stereo now all ok
Últimas 24 horas: 31
Últimos 7 dias: 224
Últimos 30 dias: 992
Duração total: 68,636
2 comentários
Sometimes my system would play for awhile then the voice will go out and only the beat will keep playing for a little bit then stop then my deck will say miswiring.. what should i do??
por Gogetta
My Kenwood did this after 2 years I knew there was nothing wrong with the car so I took the unit apart could not see any corrosion as others have had. I removed the cd mechanism pulling out the ribbon cable reassembled without the cd part and now all working so some part of the cd player became faulty.
por daniel talbot
