Ir para o conteúdo principal
Released November 2015. Identified by model number 91161.
4 Perguntas Visualizar todos
Why won't my device connect to the Xbox One?
I have tried pressing the connect button on the device, but nothing happens. Why won't my device connect to the Xbox One?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
There are two things that may be going wrong. First, you are pressing the sync button incorrectly. Make sure you are pressing the small white button with the wifi symbol on the guitar AND the connect button near the CD port on the Xbox at the same time. Hold them both down for a few seconds and the sync process should start.
If that did not work, your sync component could be broken and will need to be replaced.
Check out the troubleshooting page here for any additional questions.
Esta resposta foi útil?
Pontuação 2
Sync Component Malfunction or Faulty Sync Component.
Pontuação 0
Adicionar a sua resposta
Catherine Lintner será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 35
Duração total: 4,940
