Can you remove the VESA mount from a late 2015 Retina iMac
I have a late 2015 model Retina iMac with a 27 inch display. The iMac was purchased direct from Apple with a VESA mount pre-installed. The mount is secured to the iMac with two pentalobe screws. Does anybody know what size pentalobe screw's are used on this model iMac?
EDIT, 02/11/16 @ 16:36
I have a desk mount which is designed to attach to an iMac both with and without the VESA bracket installed. Without the VESA bracket is a much neater solution because the mount attaches directly to the metal bar which the VESA bracket would normally be secured to. Officially this mode only works with pre-2012 iMac’s where the desk stand could be removed; however I see no reason why I couldn’t remove the VESA bracket installed by Apple and attach the desk mount. That is unless there are additional screws which are not accessible from the outside of the iMac.
Esta é uma boa pergunta?
