No image transmission signal
Cannot view my camera from remote but can control and move it around record and take pics but have to view from pc
Esta pergunta é pertinente?
Pontuação 0
1 dos comentários:
Hi,
Does the remote controller screen 'light up' when you turn on the remote i.e. can you see 'backlighting' of screen?
If the backlighting is on then there may be a problem with the video connection to the screen, either a loose cable, a faulty screen or a video circuit fault on the motherboard in the remote.
If the backlighting is not on when you are connected and you can 'see' on a PC so that you know the camera is working, try shining a torch on the remote at an angle very close to the remote screen and see if you can detect a picture. If so it means that the video is OK but the screen backlighting is not.
por
Adicionar um comentário
