Ir para o conteúdo principal
The Nokia 1110 is a low-end GSM cell phone aimed at first-time cell phone users.
7 Perguntas Visualizar todos
Pergunta Encerrada
How to break security code?
i have an nokia 1110 and i didnt use it for many years and now forgot the security code .so now not to use it . i need to break the security code . help me ?
Esta pergunta é pertinente?
Pontuação 14
Adicionar um comentário
11 respostas
Pergunta Mais Útil
12345 ---> This is the default security code on all Nokia phones before a user changes it. Try this first when asked for the code.
If that doesn't work try the codes below, they may help you solve your problem but not guaranteed!
Insert the following codes from the phones dial pad:
*#7780# ---> (reset to factory settings)
*#2640# ---> (Displays phone security code in use) ??
*#7370# ---> (Deep Reset: Removes everything and puts the phone right back to factory settings)
*#7328748263373738# ---> (Resets security code)
I've not tested this one myself so i'm unsure if it will do anything!
Esta resposta foi útil?
Pontuação 8
Comentários:
x igat password
por
thanks brother
por
salaams every body i have a Nokia 106.1 i have tried all the codes available on the net and none work when i press *# it does not display and after putting all codes in it says code error I've been trying all sorts for the pass two weeks
por
Hi Abdullah valli, try this alternate way to hard reset your phone...
With the phone powered off, press and hold the Power button + Answer/End key for about 5 seconds until the red and green indicator lights start to alternate.
por
Sometimes pressing "*#code#" doesn't always work, If it doesn't work try inserting the code using this format... *#*#code#*#*
por
Mostrar mais 1 comentário
i forget to my security code
Pontuação 6
Comentários:
I forgot the security code
por
Sir me *#2640#karke dekha emargency call only bolrahahe me kiya koru
Pontuação 1
sir nokia model 1011 i forget to my security code
Pontuação 1
Nokia 1110 format code
Pontuação 0
Sir nokia 1110 ka format code kiya hai
Pontuação 0
Comentários:
Sir nokia 1110 phone format code kiya hai
por
Pontuação 0
I need to reset my code
Pontuação 0
Yes
Thanks
Nokia RM 1110
Pontuação 0
Nokia1110 want security code
Pontuação 0
I have a nokia 6700 classic and it is asking for secruity code as it has been years i can not remember the code tryd all the obvious solutions but stil not working any help guys?
Pontuação 0
Comentários:
*#7328748263373738# resets security code.
Default security code is 12345
por
If you still can't reset the security code then the only way would be to flash the phone & restore the Nokia firmware. That process involves more time on your part as you'll need to download the nokia software & the firmware specific to your device. The links below are for the "How-To" tutorial to accomplish these tasks!
Link 1= Firmware downloads for Nokia 6700
Link 2= How-to tutorial & nokia software programs
1) http://forum.gsmhosting.com/vbb/f299/nok...
2) https://www.hardreset.info/devices/nokia...
por
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 31,876
