Ir para o conteúdo principal
Coby Kyros MID7012 4Gb tablet released in 2012. The tablet is Wi-Fi Capable.
8 Perguntas Visualizar todos
Why isn't my tablet turning on?
I've tried charging my device and it still wont turn on. What should I do to solve this issue?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Assuming that the tablet is charged you can attempt a hard reset of the tablet by hitting the reset button located on the back of the device. You will need to use a paperclip or an item of similar diameter to push the reset button. If this has not solved the issue check out the device troubleshooting page.
Coby Kyros MID7012 Troubleshooting
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Devon Craig será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 2,665
