Why don't my daytime running lights work
My daytime running lights on my 2003 Toyota rav4 stopped working my headlights only work when I put them on high beem.
Esta é uma boa pergunta?
Jose,
First thing. Daytime runners are to be on when the headlights are off. Now the RAV 4 may possibly be setup to "add" them with the high beams, which may be why your seeing them.
Like the first answer said. Check the fuses, inside car and under the hood. They run through the head light switch, which could be problem.
I'll look into it and see if there is anything to be found.
Esta resposta foi útil?
Últimas 24 horas: 4
Últimos 7 dias: 7
Últimos 30 dias: 10
Duração total: 1,124
1 comentário
i would check your fuses, and then if all fuses are good try a new bulb.
por Candido Ortiz
